Well i got the trans done and back in changed all the fluids and filters pulled the truck out did a valve adjustment, fired it up and it ran for about 10 sec. then died. it was spittin and sputterin so i thought it was fuel and sure enough it was. stupid me forgot to fill the filter with fuel before i put it on and the truck sat for long enough the some fuel ran back from the lift pump back. so i filled the filter cranked for a while, primed the system and it still wouldnt fire. so i figured i got air in the injector lines which i did and i bleed them. finally got fuel comin out and im pretty sure my lift pump is shot but i dont know. is it possibly to an intermittent lift pump problem being that it is mechanical? sometimes work and sometimes not? i dont see why not but i dont wanna just buy parts and not really know. it is deffinatly something between the filter and the tank though i do know that much. not the IP. sorry for the essay but wanted to try and put in everthing. thanks in advance
chris
im gettin ready to go put it on and hopefully fire it up today just to put it back in the garage and take the head off to o-ring, port, and stud it.
