injectors???
injectors???
Postby Firstgen1 » Sun May 03, 2009 5:49 pm
would you guys recomend 370 injectors, or dinomite diesel performance 40 hp injectors as a daily driver, how much power can these injectors handle
thanks
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby cumminz90 » Sun May 03, 2009 6:26 pm
I had a set of the Dynomite Diesels Stage 4s that i used in my daily driver i have no complaints about them at all dont no about the two you are looking at tho im sure some of the others will fill u in on how they like theres :wrench:
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Re: injectors???
Postby peobryant » Sun May 03, 2009 7:26 pm
Firstgen1 wrote:would you guys recomend 370 injectors, or dinomite diesel performance 40 hp injectors as a daily driver, how much power can these injectors handle
thanks
PToombs on here runs New Era 370's and is making around 388rwhp. I plan on running a set pretty soon as well. They are a very good injector, especially for the price.
You should look into upgrading your turbo as well, if your going to be towing anything with pump mods.
