air filter cfm
air filter cfm
Postby skilletky » Mon May 04, 2009 3:52 pm
dose any one know how much cfm this filter, http://store.airflo.com/b105006.html , will flow? anyone using this filter currently?
skilletky
Postby mprmn08 » Mon May 04, 2009 4:51 pm
i believe its 680 cfm. im pretty sure its 600 something though. not exactly sure on the 680
mprmn08
Postby wjones » Tue May 05, 2009 2:23 pm
I'm running one of those. I've never seen a stat from donaldson regarding the cfm. Alot of people throw around mid to upper 600s.
1992 W250, nv4500 Club Cab
wjones
Postby skilletky » Tue May 05, 2009 3:08 pm
thanks for the info. any one know of a higher flowing filter? is this the filter that is refered to as the BHAF?
skilletky
Postby mprmn08 » Tue May 05, 2009 3:58 pm
i believe its fleetfilter.com that gives cfm for the filter along with others if you wanna check it out.
mprmn08
Postby wjones » Tue May 05, 2009 6:15 pm
skilletky wrote:thanks for the info. any one know of a higher flowing filter? is this the filter that is refered to as the BHAF?
Yes this is a bhaf. Its a pretty good upgrade as opposed to stock.
wjones
