how much power??
how much power??
Postby Firstgen1 » Mon May 04, 2009 5:24 pm
how much power do you guys think i have, 2 turns on pump, denny t pin, new era 370 injectors, intake, and 4 in exhaust
can you think of anything else i should get
tell me what you guys got and how much power
thanks
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby gear jammer 91" » Mon May 04, 2009 7:32 pm
I'm not good at guessing HP, I will say you should upgrade your lift pump though. With big injectors and your fuel screw turned in you will start starving your injection pump for fuel, which will not only hurt power, but it will also hurt the lifespan of your pump. I also picked up some of the MPG's I lost after I installed my low pressure piston pump. The governor spring is also a must do.
01 LB7
gear jammer 91"
Postby Firstgen1 » Tue May 05, 2009 3:49 am
ok thanks where can i get one of these lift pumps do you know a website
thanks
Firstgen1
Postby gear jammer 91" » Tue May 05, 2009 5:44 pm
The low pressure piston pump is a cummins part. I'm not sure if the part numbers for all the required parts are in the sticky here but they are definitely in the sticky over on http://www.dieseltruckresource.com/. I've also been told that you can get the same parts from a case dealer for less money.
01 LB7
gear jammer 91"
Postby Tacoclaw » Fri May 08, 2009 10:00 pm
gear jammer 91" wrote: I've also been told that you can get the same parts from a case dealer for less money.
Not anymore. :(
When I bought mine about 3 months ago, Case had just changed their price and it was about $70 more than Cummins charged me.
Then again, the Cummins price isn't that ridiculous to start with, I think I had about $170.00 total in mine including lines and gaskets/spacer.
Postby gear jammer 91" » Sat May 09, 2009 9:36 am
If I had went directly to cummins it wouldn't have been so bad for me, but I went through a local shop cause I didn't know any better :oops: . I think it cost me around $250, but that's ok, It's just money :lol: , and I like the shop I gave my money to.
01 LB7
gear jammer 91"
Postby mprmn08 » Sat May 09, 2009 11:34 am
well i just bought the pump and everything to convert mine to a piston LP and it was 260 total from cummins.
mprmn08
Postby peobryant » Sat May 09, 2009 12:41 pm
What exactly did you need besides the pump? A spacer?
$260 doesn't seem too bad, the low pressure piston pump has skyrocketed in price. :cry:
Postby gear jammer 91" » Sat May 09, 2009 9:55 pm
Go to DTR and in the first gen tech section they have a list of all the parts you need to do a piston pump with the part numbers.
01 LB7
gear jammer 91"
