ve pump adjustment
ve pump adjustment
Postby deanhinsley1963 » Wed May 13, 2009 11:03 am
if i take out the fuel screw to take off the steel collar will it leak fuel and cause me to have to bleed inj.? i was going to turn it about 2 turns.
deanhinsley1963
Postby Firstgen1 » Wed May 13, 2009 12:45 pm
it mite leak a couple drips but you will not have to blead the injectors
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby peobryant » Wed May 13, 2009 2:01 pm
Shouldn't have a problem.
Remember to have a sturdy 2X4 ready, in case it runs away.
Postby gear jammer 91" » Wed May 13, 2009 6:53 pm
I had no issue's with mine, on my brothers truck it kinda acted up the next day, but nothing major and the air worked itself out.
01 LB7
gear jammer 91"
ve pump adjustment
Postby deanhinsley1963 » Thu May 14, 2009 8:47 pm
Thanks for the replys guys. I'm new at this (ve pump).
deanhinsley1963
Re: ve pump adjustment
Postby peobryant » Thu May 14, 2009 9:00 pm
deanhinsley1963 wrote:Thanks for the replys guys. I'm new at this (ve pump).
You do know about runaway, right?
Postby DoWhat? » Fri May 15, 2009 11:39 am
Thats a scary and possibly expensive lesson to learn if he doesn't lol.
-91 W250 day cab 5 speed
strait pipe, monkey pump, big tires
-96 Ford F-250 PSD
strait pipe, big injectors, tunes
DoWhat?
ve pump adjustment
Postby deanhinsley1963 » Sat May 16, 2009 5:46 pm
Yes I've heard about runaway will have 2x6 handy!!!!! Thanks guys I just turned smoke screw 3 turns,star wheel all the way down,fuel pin to deepest setting really helped. Have not turned fuel screw yet but was thinking about 2 turns. I should be safe from runaway with that RIGHT!!!! Will have board handy thought. How much can you get out of it with the collar still on the fuel screw? Was thinking of turning it in to collar and see what i got out of it.
deanhinsley1963
ve pump adjustment
Postby deanhinsley1963 » Sat May 16, 2009 5:47 pm
deanhinsley1963
Postby RumbleFish » Sat May 16, 2009 7:40 pm
you dont have to worry about runaway until you mess with the fuel screw. and if the collar is still on it, i HIGHLY doubt you have anything to worry about, but having the 2.6 ready is a good idea regardless. fwiw, when i turned the screw into the collar on my 91, it went a whole 1/2 turn before it bottomed out.
Users browsing this forum: No registered users and 66 guests
