ve onan pump case same as 12v ve case.
Postby cumminsram » Sat May 16, 2009 9:07 am
Im in need of a pump case for a ve rotary pump because the one on the truck is cracked so we removed it. Is it possible to put my internals from the 12v pump with a 12mm plunger to the onan pump case with a 10mm plunger because all we need is a new case? Or does anyone know of a cheap ve case or cheap pump because all we need is the case.
03 duramax reg cab 4x4 6sp blue, daily driver
93 w350 reg cab 4x4 5sp single wheel
sold: 1993 auto 4x4
SOLD:1990 power ram 250 4x4 5sp
cumminsram
