I pop tested my injectors, they range from 2,500 PSI to 2,900 PSI; spec is 3,550 PSI?
Anybody know where I can get shims? Any reason why not to use hardware store washers and beer can holes?
Begle1 wrote:I went to Ace with a caliper, turns out that "3 mm flat washers" are the exact same diameter (by my standards) as the shims that were in the injector. So I got 25 of those. I'll see how that works tomorrow...
I imagine that it is possible to get coil bind by using too many shims? I would hope that if that were to happen I'd notice it on the pop tester?
Richie O wrote:Man, and I thought I was cheap.
