VE pump problem
VE pump problem
Postby tripler54 » Fri Jun 05, 2009 10:20 am
I got a truck that had a leak in the pump between the main pump body and the upper housing (with the throttle shaft in it) . so i replaced the seal/gasket and noticed there was a small crack on the inboard side just below the step down from the idle screw so i pulled it back off and changed everything out to a housing i had and installed it, worked great for bout a week not a single drip until last night i noticed a leak and sure enough the new housing was cracked in the same place. Im kinda baffled since it went on nice and was working great. the only thing i can think of is that the housing might have a little warp in it causing the crack.
never seen anything like this before and was wondering if anyone had any input or has seen somthing similar.
tripler54
Postby Begle1 » Fri Jun 05, 2009 6:05 pm
Ouch.
I'd have to think that it'd be a warped pump too...
Either that or you're godzilla with the allen wrench putting it on.
Maybe the AFC hose has turned into a super-spring somehow and is torquing it over.
Maybe you're putting so much boost into the diaphragm chamber it can't take it anymore!
