J-jets?
J-jets?
Postby Begle1 » Tue Jun 09, 2009 5:25 pm
Do we have saddle jets or J-jets? Do we have the oil rifle for J-jets?
Postby KTA » Tue Jun 09, 2009 7:06 pm
Unless you put a common rail motor in you have saddle jets and there is no provision for j-jets.
Postby IowaCummins » Wed Jun 17, 2009 8:05 am
can i ask what you guys are talking about? im either thinking oil jets or maybe injector spray something? am i close or way off
IowaCummins
Postby Begle1 » Wed Jun 17, 2009 1:02 pm
Oil jets for the pistons.
Everything before the common rail has saddle jets that get their oil from the main bores. When they went to the common rail they put a new drilling in the block for J-jets that shot oil more directly into the piston.
Common rail 5.9's have provisions for both; lower horsepower engines had the saddle jets and higher horsepower engines had the J-jets. With the 6.7, they all have J-jets and saddle jet provisions no longer exist.
Postby KTA » Wed Jun 17, 2009 1:04 pm
J-jets are the cummins term for the bolt in piston cooling nozzles which do spray oil. In the 6b series they are intended to spray into a gallery in the bottom of the piston that allows more cooling to the piston crown. That is how come they can run continuous 1300+deg EGT and make 325rhwp without melting down.
Postby IowaCummins » Wed Jun 17, 2009 1:38 pm
ahh ic ok cool. i figured it was something like that. thanks guys i get more smarter on here than at skool! lol
IowaCummins
