Diesel tach
Diesel tach
Postby fasttalker83 » Wed Jun 10, 2009 5:23 am
My tiny tach is shooting craps maybe just wiring but oh well has anyone had good success with the autometer Diesel tach's and is the probe on the alternator pretty accurate
fasttalker83
Postby RumbleFish » Wed Jun 10, 2009 6:16 am
i had a autometer tach in my crew, and it was ok. fairly accurate, but that depends on you. you have to calibrate it to the truck with a dyno or hand held tach, by adjusting a screw on the back. i did it by ear, and had pete check it at sop. it was about 50 rpm shy of being right.
Postby 1dumrednek » Wed Jun 10, 2009 11:34 am
i have the autometer tach on mine. i like it but wy alternator is messed up so it twitches real bad at an idle. same with the alternator gauge. it smoothes out around 1200 rpm. but the tach itself is really good.
A.J.
91.5 Power Ram w250 LE 5spd reg cab... totalled... again
2002 2500 laramie slt plus sport, nv5600, MBRP 4" straight pipe, edge juice w/ attitude, DC1 rims, kelly fierce attitude M/T
1dumrednek
Postby Richie O » Wed Jun 10, 2009 12:33 pm
Do you guys not like Isspro tachs??
Postby RumbleFish » Wed Jun 10, 2009 12:45 pm
my crew had it in there already. it was a conversion, so it didnt have the factory plug under the dash. isspro is better tho.
Postby PJ 3 » Wed Jun 10, 2009 12:48 pm
Richie O wrote:Do you guys not like Isspro tachs??
There's no mod's to my motor yet but that will be my next investment. I might buy them from Geno's. What a father's day gift ! :D
Pete
1992 W250
PJ 3
Postby Richie O » Wed Jun 10, 2009 1:12 pm
Both of mine I got directly from Isspro. Geno's does not have the 4,000 rpm unit. The only one they list is the 3k one. They ( geno's ) asked me to go direct instead of them doing a special order and then ship it to me. The price was about the same anyway.
Postby Ace » Wed Jun 10, 2009 7:21 pm
I have an ISSPRO 4k 2-1/16" tach I found on eBay over three years ago for $25. I had to cob up a fitting for the lightbulb and install a crank sensor (which ISSPRO sells). But it's been great for three years and counting now....
Ace
Postby jogl » Thu Jun 11, 2009 3:00 am
I have an Isspro with the crank sensor. I had to fab up sensor mount. When I had the etest done it was reading right dead on. Has a nice steady needle too.
JP.
92 W250 and lots of others.
jogl
Postby seeker1056 » Tue Jun 16, 2009 10:55 am
who has a link to the ISpro tach and can anyoen tell me if the factory pickup sensor o nmy 93 will run it?
How much as well
thanx
Ken
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby Richie O » Tue Jun 16, 2009 5:34 pm
Scroll down to page 13 in this link. I have the R8503 with the R8912 sensor on my 89. I have the EV series R5503 and I bought the R8912-92 wire package for the factory plug on my 93. I ended up making my own harness so all I used from the wire kit was the directions. :evil: The EV series gauges are twords the bottom of the pdf file. Do you have the factory pcm as well as the crank sensor. If you do then you could hook it up. I would suspect it might be easyier to wire it like my 89 with no pcm.
http://www.isspro.com/catalog/ISSPRO%20 ... 202006.pdf
