Engine Oil
Engine Oil
Postby Farmboy » Wed Jun 10, 2009 10:03 am
Very dumb question, but I don't have a manual for this truck... what weight of oil and how much oil do these motors take? I need to change my oil. I haven't done it since I bought the truck yet so I think it would be a good idea. Probably should have done it sooner but didn't have time.
Farmboy
Postby SOOT4BRAINS » Wed Jun 10, 2009 10:30 am
Above 10 degrees f, it calls for 15w40. If colder than that, it wants 10w30, and if its below 0 with no block heater it calls for 5w30 synthetic, with block heater is 10w30. Mine takes just over 13 quarts to fill up. I use the valvoline blue 15w40.
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
SOOT4BRAINS
Postby Ace » Wed Jun 10, 2009 5:20 pm
Or you can use a 5w/40 and not worry about the temperature. Just make sure it is a minimum CI4+ diesel-rated oil - no gasser oil.
Ace
Postby burnt_servo » Fri Jun 12, 2009 12:11 am
my dad has a '98 and '99 cummins , my sister has a ' 89 jetta diesel , and my '91 jetta all run 0w-40 all year round ( we buy it by the 5 gallon pail )
with my vw i noticed a definate improvement in fuel consumption with the lighter oil .
once i finish my '93 dodge , i intend to put it on the same diet .
'93 w250 .... stock ...
burnt_servo
Postby Farmboy » Tue Jun 16, 2009 7:32 am
Thanks guys. It ended up taking 13 qt. Now.... how often do you change the oil. My dad said probably 5-6 thousand miles. What do you think.
Farmboy
Postby Richie O » Tue Jun 16, 2009 5:43 pm
I always did 3 to 4 k but thats overkill. Usually its because its been a year or so since, not that Im over milage. I usually only do 3 k a year. :oops:
Postby PJ 3 » Tue Jun 16, 2009 6:47 pm
In the 18 years that I've owned my truck I have changed every 5000 K
and the engine still run's clean. I run Rotella...........
Pete
1992 W250
PJ 3
