should i swap turbos
Postby skilletky » Mon Jun 22, 2009 12:31 pm
i went to the track last week and finally got to really get on it with the new trans and converter. well the turbo lags real bad! even power braking it and spooling it to any where from 5 to 10 psi it still seems like it is taking it too long to build boost. i was thinking of swapping to a 62/65/14. is this a good idea or should i keep my turbo i have in my sig and just deal with it? oh, and it ran a 15.00. hoping to hit the 14's range this weekend, tinkered with the wastegate and fixed my throttle linkage problem.
skilletky
Postby SNOOT » Mon Jun 22, 2009 12:33 pm
What are your EGT's and have you checked your drive pressures?
You may need further adjustment on the waist gate?
1993 W350
SNOOT
Postby skilletky » Mon Jun 22, 2009 12:39 pm
egt's just about hit 1280 when i crossed the line. i have yet to check drive pressure again. i forgot what it was when i last checked it but it was with the old trans and converter.
skilletky
Postby bgilbert » Mon Jun 22, 2009 12:41 pm
Time for injectors. NE370's are not known for making hp in a 1st gen. Or send back the 14cm housing and tell them you want a 12cm or .70ar housing. That will spool a little faster.
Bill Gilbert
bgilbert
Postby skilletky » Mon Jun 22, 2009 12:45 pm
i am gonna get a set of 6x16's next month, i thought about getting a 12cm housing but was worried about drive pressure and egt's getting out of control. i guess i could use an external wastegate with the 12cm housing.
skilletky
