All right, I need some help from those of you with more knowledge then me.
When my mid 92 intercooled truck is running and warmed up, and you stoMp the throttle half way or all the way, it puffs a little black smoke, follwed by a puff of grey smoke that fades to white.
Also the truck has started acting as if it is getting less fuel than before.
I know the smoke screw is turned in 2 turns, the fuel pin is turned with the deepest seting to the front of the engine, and the full power screw is turned inabout 1-1.5 turns past stock.
finally i took a bottle of soap/water and could find no leaks around the injectors, lines, IP, lift pump or fuel filter.
ANY ADVICE IS WOULD BE GREATFULL
