As info for anyone with a nonI/C
Through the winter I added an I/C to my ist gen. A little more pipeing then I would have liked but Freightliner left me no choice that I could find.
Just did my first real trip and results were pretty good. if this were just a pickup that went unloaded all the time I doubt it would be worth it or necessary, but.....
My 1990 motorhome is over 12,000lbs and then I hang a Chevy Malibu off the rear. I keep pretty good baseline records over time over same roads.. The I/C gave me a steady 100* reduction in EGT at 60 + MPH level ground.
That may not seem like much. The best improvement came on the uphill. Much slower increase in EGT's at pretty close to WOT and I never got to max egt on hills that had always caused me to back off, or downshift near the top.
Boost numbers are down from 15+max to 10+, but better power than before. Maybe a leak but I can't find any, and dosen't seem to be a problem,
Starting is a little different, longer crank time, a puff of black smoke, and a little lighter color smoke in cooler weather. (spool up is not tooo fast) Things to look at but pretty good result over all.
Thanks to folks that helped with suggestions.
