wastegate
wastegate
Postby OLDEARL93 » Sat Jun 27, 2009 6:54 pm
Does anyone know if the wastegate of the 2nd generation hx35 turbo is set at 22 lbs, yesterday I towed my boat to the lake for some bass fishing and my truck did fine except that if I pushed it up up the hills on 4th and put it to 20 plus lbs of boost after a bit the wastegate would come on, I would loose boost , I let of the throtle and it would set it self and it would be ok without towing the truck has a 8 foot camper but it never did this before,if anyone has the same problem how did you fixed it.
93 4X4 EXTRA CAB 5 SP. GERT.EGT,BOOST ,RPM GAUGE,TIMMING AD,PUMP TWEEKED,NEW HX35,REST STOCK
OLDEARL93
Postby Ace » Sat Jun 27, 2009 6:59 pm
You probably don't need or want a wastegate with stock injectors. My 12cm/60mm hybrid never made more than 30psi boost with a BD fuel pin, the fuel screw all the way in and the WG bolted shut. I actually removed the wastegate bracketry and used the holes to mount a small apparatus that literally bolts it shut tight. I backed the fuel screw out a couple turns after installing W/M to keep max boost below 30psi.
Ace
Postby OLDEARL93 » Sun Jun 28, 2009 10:25 am
I wanted to know if I was wrong about this being the wastegate since I never had one before is that the problem I have or is it something else
OLDEARL93
