injector leak?
injector leak?
Postby cumminsram » Thu Mar 15, 2007 8:00 am
My mid 3 injectors are leaking and I cant quiet tell where it coming from does any one know what could be wrong. The fuel is sitting in the recess at the top of the injector nut. I dont know wether its coming from below or what? :?
Thanks,Jesse
03 duramax reg cab 4x4 6sp blue, daily driver
93 w350 reg cab 4x4 5sp single wheel
sold: 1993 auto 4x4
SOLD:1990 power ram 250 4x4 5sp
cumminsram
Postby Philip » Thu Mar 15, 2007 9:39 am
Get yourself a can of carb/brake cleaner and spray everything down. After its dry and clean start it up and watch for the leaks.
Postby Begle1 » Thu Mar 15, 2007 3:44 pm
I've heard that leaks are normal, but if your filling your injection recess with fuel that seems rather extreme.
4 of mine bubble when I shoot 'em with soapy water, but I don't have any visible fuel leaks. I've heard that the copper washer between the injector and head, coupled with age or faulty installation, is the most common cause of leaks.
