93 Tow truck build.....
Postby LOGANSTANFORTH » Tue Jun 30, 2009 8:02 am
so i want to do some work to my 93 flat bed, im thinking some type of turbo upgrade (wether it be complete turbo swap or just compressor and turbine housings), i can get great deals from a local shop in orlando and tampa on pretty much any turbo i could ever want so thats no problem, bigger injectors of some sort, maybe 435's or 6x16's if i got enough air, and of course exhaust, well actually just the down pipe, i have to get the rest custom made or modify a kit cause of the flat bed on the truck hangs low, i got a good smooth firm shifting low mileage tranny so im thinking a suncoast lockup converter and a good valve body with a MILD shift kit......
here is the turbo im looking at, i know its got a T4 flange but i am going to call and see if i can get one in a T3, which im hoping i can.....
S361
A high-flow, medium-frame turbocharger with compressor flow over 62 lbs/min. Will service 600+ HP
Wheel Dimensions: Compressor: 61.5mm inducer,87.4mm exducer
Turbine: 79.9 mm inducer, 70.8mm exducer. Cast in Inconel 713, for high-temperature operation.
Housing A/R: Compressor: .55, with 4.0" hose-type inlet, and 3.0" hose-type discharge
Turbine : 1.51, with 'T04' type turbine inlet flange, and quick-release v-band discharge
http://diesel-plus.com/dd_turbo.cfm?npid=7256
I was also looking at this one if i can get enough fuel to spin it good, i may ask if they got a 62 or 64 available though.......i may end up using one of these on my 96 pulling truck if it will tech legal.......
S366
Currently the highest-flowing S300 unit available, with maximum compressor flow over 78 lb/min. Will service 780+HP.
Wheel Dimensions: Compressor: 66.1 mm inducer, 91.4 mm exducer, with exclusive Extended Tip Technology. Turbine: 79.8 mm inducer, 73.4 mm exducer. Cast in Inconel 713 for high-temperature operation.
Housing A/R: Compressor: .55, with 4.0" hose-type inlet, and 3.0" hose-type discharge. Turbine: .91, with 'T4-style', divided entry, and 4.21" v-band discharge.
http://diesel-plus.com/dd_turbo.cfm?npid=9784
THEY PUT THEM ON A PLANE TO SOME STRANGE AND FOREIGN LAND, THEY SAID GOODBYE TO MOM AND DAD AND HELLO TO UNCLE SAM, THEY NEVER THOUGHT THE DAY WOULD COME WHEN THEY MIGHT HAVE TO KILL A MAN, THEY DID NOT SLEEP A WINK THAT NIGHT BUT THEY WON FOR UNCLE SAM
LOGANSTANFORTH
Postby K 30 » Mon Jul 13, 2009 10:21 am
is the s 361 a good turbo?? anyone or u try it??
am going to do a 1st gen cummins swap, and also a nv4500 swap in a k30 truck!!
K 30
