Denny T fuel pin
Denny T fuel pin
Postby 92CTDin916 » Thu Jul 16, 2009 12:04 am
Hey guys..just ordered a Denny T stage 2 fuel pin... anybody have one? if so how do you like it? I have a bully dog pin installed now.. and I'm not too impressed with it..
1992 W250 club cab, Auto, Minor pump tweaks, full 4inch exhaust turbo back, no muffler =) 16cm Turbine,ATS exhaust manifold, ASA Mods Intake, CoolerTubz, DennyT stage 2 Pin.. Full Gauges...5th and best Cummins I've ever owned!
92CTDin916
Postby Free89W350 » Sun Aug 23, 2009 7:20 pm
I personally dont have one but have read allot of great things about them. If I could afford it I would get one in a heart beat.
05 GMC Sierra Z71 6.5" lift and 35's
95 VW Golf VR6 5 spd
Gone but not forgoton :(
89 W350, Auto, Non Intercooled, 3.07 rears, Star wheel full up, full power as far as possible, smoke screw just a plug, fuel pin ground & washer shaved .90, 366 spring. Jardine 4" exhaust.
Free89W350
Postby TTipswprd » Mon Aug 24, 2009 1:34 am
I have had no isssues at all with it and am very pleased. very good bang for your buck. youll be happy :rock:
TTipswprd
Postby 93_Fummins » Mon Aug 24, 2009 7:41 am
I went from the Ol' Smokey type pin (similiar to the Bully Dog) to a DennyT right before my #1 piston gave up, and I loved the difference! The DennyT, just as the profile suggests, fuels harder at low boost than the Ol' Smokey did. However, that's not saying that the Ol' Smokey pin wasn't fun too...it just had a weird lag where the profile humped, but once over the hump it was off to the races. Lots more smoke on take off with the DennyT. But, you can play with the smoke screw and the starwheel to "fine tune" it with either pin.
93_Fummins
Postby peobryant » Tue Aug 25, 2009 12:46 am
I love mine, and it added quite a bit of pep to an otherwise stock truck. Definitely worth the $100 to me.
Postby james-93-12valve » Thu Aug 27, 2009 11:37 am
can you put a diffrent fuel pin in a stock pump
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby Free89W350 » Thu Aug 27, 2009 3:33 pm
james-93-12valve wrote:can you put a diffrent fuel pin in a stock pump
Yes you can
Free89W350
Postby peobryant » Thu Aug 27, 2009 6:39 pm
Yep, my pump is stock, other than the DennyT.
Postby Gunmetal » Sun Sep 06, 2009 2:00 am
How was your mileage with dennys pin if you kept your foot out of it?
I will be posting some 1st gen 12v tech articles on 1stgen.org and at my articles site soon. 12Valve.com
Gunmetal
Postby peobryant » Sun Sep 06, 2009 9:50 am
Gunmetal wrote:How was your mileage with dennys pin if you kept your foot out of it?
No difference that I could tell, but since my odo doesn't work, I can't tell you with 100% certainty. Most guys will tell you mileage won't be affected though.
Postby Gunmetal » Sun Sep 06, 2009 12:09 pm
Actually I've heard good things about power with Dennys pin, but economy is not so great. Just wanted to see if this is what y'all are seeing as well.
Gunmetal
Postby whereswaldo250 » Sun Sep 06, 2009 12:31 pm
Hows does the pin wear? Does it develop a groove over time? I hear some pins get a groove if it is not made out of hard enough steel. I have a stock pump and I have been thinking about it.
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Postby peobryant » Mon Sep 07, 2009 8:24 pm
whereswaldo250 wrote:Hows does the pin wear? Does it develop a groove over time? I hear some pins get a groove if it is not made out of hard enough steel. I have a stock pump and I have been thinking about it.
If you take the cone out in a few thousand miles, there would be a noticeable wear mark, where the pin rides the cone, but it won't be a gouge. He uses very hard steel, the prevents gouging.
As far as mileage, most of it is controlled by the right foot.
