wat is runaway
wat is runaway
Postby james-93-12valve » Fri Jul 31, 2009 10:20 am
wat is runaway im new to diesels and i was just wondering
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby Philip » Fri Jul 31, 2009 12:22 pm
A run away is when a diesel gets uncontrolled fuel. The engine will rev till it explodes most of the time. A few examples are. A turbo failure can cause it. An injection pump failure can cause it. In our case turning the fuel screw in to far can cause it. A diesel can run on about anything that will burn if it gets pulled into the intake.
About the only way to kill a runaway is to stop air flow into the engine.
Postby RumbleFish » Fri Jul 31, 2009 12:26 pm
or after its sucked all the oil out of the crankcase
Users browsing this forum: No registered users and 65 guests
