My truck sprung a leak (fuel)
Postby gear jammer 91" » Sun Aug 09, 2009 2:52 pm
My injector return line started leaking at the T fitting on the back of the cylinder head. Is there a seal back there that can be replaced or do I need to find a new fuel return line?
01 LB7
gear jammer 91"
Postby dpuckett » Sun Aug 09, 2009 7:21 pm
Is this the line that goes from injector to injector on the pass side of the head, or the one that goes from the T-fitting in the rear, back to the IP? If tha latter, I have a $20 fix that bypasses the (in 06) $75 Cummins replacement.
Dan
Postby gear jammer 91" » Mon Aug 10, 2009 6:02 am
It's the one that goes from injector to injector, and then back to the T-fitting. Do you think this is something cummins would have?
01 LB7
gear jammer 91"
Postby gear jammer 91" » Mon Aug 10, 2009 5:38 pm
I added a small O-ring to the original rubber seal on the return line and it stopped the leak. My local cummins guy was having a hard time finding the part, so I took it into my own hands.
01 LB7
gear jammer 91"
Postby dpuckett » Mon Aug 10, 2009 6:57 pm
Sounds like a good plan.
DP
