Boost #s?
Boost #s?
Postby DieselSharker » Wed Aug 26, 2009 10:20 pm
So I've had the new rig now for almost a week and so far the top psi I've hit is about 24 at low speed. Driving around the mall parking lot I kept jabbing it to see where it was at and I got about 23-4. Before I turned the smoke screw I was getting only about 18. Tonight I ran out to get some food and I was only hitting 20 before it flattened out. Lately I've been hearing numbers up to 38 from other 1st gen owners. As far as I know per the previous owner the fuel screw hasn't been touched. All my mods are in my sig. Any ideas?
1991 W250 727, 6" Skyjacker, 37" Dick Cepeks, Gear Vendor O/D, SDX 5x.014s, BHAF, home-made 4" intake, VE tuning & DennyT II pin, GDS 60mm with 16 cm, CoolerTubz 3" crossover
SUPPORT YOUR VETERANS!
DieselSharker
Postby TTipswprd » Wed Aug 26, 2009 11:03 pm
i hit 25 max with my truck and i have the pump tuned. i dont know how much altitude effects things but if you can get more than 25 id say thats good
TTipswprd
Postby 12valve350 » Wed Aug 26, 2009 11:23 pm
im right around 20/21, the most i ever got was 23
Six in a row makes 'er go, Eight in a v, theres nothin' too see!
12valve350
Postby peobryant » Thu Aug 27, 2009 6:28 am
Is this truck Non I/C or Intercooled? What are the size on those Bully Dog injectors? Is the auto stock?
Postby DieselSharker » Thu Aug 27, 2009 10:43 am
peobryant wrote:Is this truck Non I/C or Intercooled? What are the size on those Bully Dog injectors? Is the auto stock?
Non-I/C, 80hp sticks and I'm pretty sure the valvebody is aftermarket. Plus it has a Gear Vendor behind it. Nice avatar btw. I am a little obsessed with Zep. I have a box set with little mini replica LP covers and every album that I listen to straight through all the time.
OK you guys just made me feel a lot more comfortable.
DieselSharker
