can you put a diffrent fuel pin in a stock pump
Postby james-93-12valve » Thu Aug 27, 2009 11:48 am
can i do these mods with the stock pump fuel pin and injectors and feel a diffrence and still get good milage
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby Begle1 » Thu Aug 27, 2009 2:05 pm
"Yes."
Postby peobryant » Thu Aug 27, 2009 6:40 pm
Yes sir, you can. ;)
Postby Old 'n Rusty » Tue Sep 01, 2009 5:02 pm
Your truck has small injectors and won't get real frisky but you can get some improvement by tweaking the pump. The fuel pin may not make a lot of difference till you get bigger injectors. Get a pyrometer to monitor things.
Early '91, Getrag, gauges, light mods,492 k., 354
Old 'n Rusty
