Those three bolt holes...
Postby Begle1 » Sat Mar 31, 2007 3:02 pm
I think I've asked before, but I forget...
What are those three bolt holes for on the front driver's side of the engine?
And can I mount 15 pounds worth of stuff on one safely?
Postby BobS » Sat Mar 31, 2007 3:38 pm
Those are alternative engine mounting bolt holes. They actually are on both sides. Interesting side note is the 4BT automotive engine mounts bolt right on in this location. Then the other mounting set are the four on the front that uses the U shaped mount that goes under the balancer and are used with the SAE engine adapter. That should be enough of my worthless knowledge on alternative engine mounts :?
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby Begle1 » Sat Mar 31, 2007 5:38 pm
Engine mounts on the top of the engine, eh?
Well, if that's the case, I wouldn't be hesitant to hang 15 pounds off the side of it.
Fuel heater shall be installed!
Postby BobS » Sun Apr 01, 2007 4:32 am
The three on the top front on the cylinder head are accessory mounts. I have a vacuum pump that will mount in that location. Did I get the right three this time? :?
BobS
89 D350 Stock
BobS
Postby PToombs » Sun Apr 01, 2007 6:36 am
It would have been easier if he had said "on top of the head" :oops:
Postby Begle1 » Sun Apr 01, 2007 3:03 pm
Yeah, I'm talking about the three on the head that say "peek-a-boo!" when you open the hood.
I don't mind thinking they're alternative engine mounts if you want my to...
