Light White Idle Haze on a Stock Truck
Postby Begle1 » Sat Mar 31, 2007 5:44 pm
Since I've had my truck, it's liked to haze a bit at idle. I don't notice it much, usually only on hot days when I'm running it really hard. I'll pull to a stop and the I'm hazing light white smoke for a few yards out of the exhuast.
I was thinking it might be valves, but they're at spec now (and weren't really out of spec to begin with).
Is the haze normal, or do I need to look at my injectors or timing?
Postby wannadiesel » Sun Apr 01, 2007 9:17 am
Sounds like the injectors are tired. You can give it some extra timing and it might clear up.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Sun Apr 01, 2007 3:00 pm
Nozzles-worn-down tired or need-to-be-rebuilt tired?
Postby wannadiesel » Sun Apr 01, 2007 4:54 pm
Wore out nozzles and needles.
Best dyno: 408/844
wannadiesel
diesel guru
Postby dpuckett » Tue Apr 03, 2007 8:19 pm
They arent expensive to get cleaned and reset to specs. I've gained up to 4mpg by that alone.
DP
Postby Begle1 » Tue Apr 03, 2007 8:38 pm
dpuckett wrote:They arent expensive to get cleaned and reset to specs. I've gained up to 4mpg by that alone.
DP
So can somebody enlighten me on the options for rebuilding injectors?
It's possible to get them adjusted back to in-spec pop pressure, which is required every hundred thousand miles, but if the nozzles are worn you need to spend $300 on new nozzles?
Either bad nozzles or pressure can cause white smoke?
What's a needle?
Postby 90firstgen » Tue Apr 03, 2007 10:35 pm
The pump shops around here wanted like $18 bucks per new replacement nozzle. $300 is insane!
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby Begle1 » Tue Apr 03, 2007 11:10 pm
I thought nozzles were way more than that.
Can anybody show me a schematic of an injector? The nozzle is the tip with the holes in it, correct?
Postby 90firstgen » Wed Apr 04, 2007 12:34 am
Can't show you a schematic but yes that is correct.
3200 Spring
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
Stan's 4"
90firstgen
Postby JLeonard » Wed Apr 04, 2007 4:43 am
I have the VE manual in a PDF format. If you want it send me an e-mail to
leonaj99@yahoo.com
and I can reply with it. I think it has a cross section of the injector in there. Good ref material regardless.
On injector rebuilding....
The going rate around here (Ct) is about $55/60.
You need to decide whether you want to spend for rebuilding or if you want to upgrade.
2 years ago I decided to upgrade. I spent about the same $
Jay
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby ekk33 » Wed Apr 04, 2007 6:42 am
I sent you an email for the manual
So I can add it to the collection
Thanks,
Eric
1992 W250
Cooler Tubz, PS Intercooler
Pump Mods,3200 Spring,
ekk33
Postby JLeonard » Wed Apr 04, 2007 12:24 pm
And I sent you a manual for the email :lol: [/quote]
JLeonard
Postby Begle1 » Wed Apr 04, 2007 3:44 pm
I already got that Bosch manual too. I've read through it a couple times but the only conclusion I've come away with is that they deserve the money they get.
So how much money should these injector rebuilds cost? $60 per injector, including the $20 per tip, would be a good price?
How long does the rebuild take if I drop them off in town?
That'd be $360, for $400 I could get POD's, but I'd need water injection and turbo mod's to do that. And then I would be hazing lots more at idle, so it would defeat the purpose, wouldn't it? Now I'm starting to think like the government... :?
I got the 9 mm injectors, so I don't think there is much I could upgrade to without paying ~$800 for customs, which I'm not ready for yet regardless. Maybe buy some 7 mm 190's in case I ever wanted to put a 7 mm head on...
Postby 90firstgen » Wed Apr 04, 2007 5:42 pm
Just call around to pump shops and ask them what they would charge for the rebuild. The one I went to just charged labor and I can't remember what I paid just for that because I had some other things done too like the 3200 spring, a couple pump seals, etc...
3200 Spring
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
Stan's 4"
90firstgen
Postby Greenleaf » Thu Apr 05, 2007 3:54 am
I just removed my 320,000 mile 9 mills. I installed 185's 7mm injectors. It took away the idle haze and rough idle. However, I think I'll swap then out for POD's.
The 7mm units are more popular. Make that ten times more popular. You can move them if your not happy with them.
Greenleaf
tech specialist/mod
