REAR MAIN SEAL
REAR MAIN SEAL
Postby redwood logger » Mon Sep 14, 2009 12:36 pm
Can someone give me a quick run down of what parts I have to remove to replace the rear main seal on my 93' 12 valve? This info would be much appreciated.
redwood logger
Postby diesel freak01 » Mon Sep 14, 2009 1:31 pm
should be just the tranny and the oil pan but having never done one im not for sure
1993 d350 ctd drw 2wd auto
diesel freak01
Postby TRENDZ » Mon Sep 14, 2009 3:17 pm
TRansmission, flex plate or flywheel. Buy the seal from cummins and it will come with an installation tool and instructions.
TRENDZ
Postby PToombs » Mon Sep 14, 2009 6:13 pm
Yup, no need to remove the pan or the adapter plate. If the truck is in a rust belt area or even if it isn't, it's a good idea to pull the adapter plate and check the rear cam plug. It's only a few more minutes, and sometimes the plug will be leaking or rusting out.
