by Begle1 » Tue Sep 22, 2009 9:51 pm
There are exhaust gas temperatures and piston temperatures, and the two may be directly or inversely related.
Gasoline is very well dispersed with air in the cylinder; when the mixture burns, it is possible for all of the fuel to only burn partially, and CO is created instead of CO2.
Diesel fuel disperses while it is burning, so the fuel that does burn burns completely into CO2 while the rest of the fuel doesn't burn at all. No CO is created, but the totally unburnt fuel comes out as black soot. The Diesel fuel needs more time to finish burning than gasoline since it needs time to disperse.
Black smoke can be caused by there not being enough air for the fuel to react with, or by there not being enough time for the fuel to mix and react with the air. The newer the injection system the more efficient it is and the less time it takes for it to burn a given quantity of fuel.
When fuel is injected inefficiently, it doesn't have enough time to combust on the power stroke and the combustion continues during the exhaust stroke. This causes "afterburning" in the manifold and increases exhaust gas temperatures. Afterburning does not necessarily cause an increase in piston temperatures.
When fuel is injected efficiently, more of it combusts during the power stroke and piston temperatures are therefore higher. This doesn't necessarily cause an increase in exhaust gas temperatures.
Unburnt fuel by itself is a coolant. Black smoke tends to cool the pistons, even if it afterburns and increases EGTs.
When you put more air through the cylinders, it will almost always result in cooler piston temperatures and exhaust gas temperatures, unless the turbocharger is making that air really hot.
