P/S pump spacers/ bushings
Postby dpuckett » Thu Sep 24, 2009 3:05 pm
Hey, can someone get me a measurement of the length of the little spacers that square up the p/s pump to the vacuum pump on an intercooled truck? The ones that go behind the studs on the engine side of the pump? Some cheesedick decided not to reinstall them somewhere up the line before I got the truck. Dodge has them available for $25 EACH!!! I bought some studs, and am going to cut some steel pipe to the right length. Only problem is, I dont know that length.
Daniel
Postby BobS » Thu Sep 24, 2009 4:05 pm
I get a measurement of 0.372" so figure 3/8" You may want to look at www.mcmaster.com part number 8491A726 which is a headless fit bushing which is 3/8" id x 1/2" od x 3/8" long. It's a tad bit on the skinny side but a few matched flat washers could fix that. You need to keep the dimensions close otherwise the shaft will become offset in the seal.
Type
Press-Fit Drill Bushings
Material
Steel
Steel Material Type
Case-Hardened Steel
Fractional Drill Size
3/8" (.375")
System of Measurement
Inch
Inside Diameter
.375"
Inside Diameter Tolerance
+.0001" to +.0005"
Outside Diameter
1/2"
Outside Diameter Tolerance
+.0014" to +.0017"
Length
3/8"
Length Tolerance
±.015"
Rockwell Hardness
C61-C65
Specifications Met
American National Standards Institute (ANSI)
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
