Is this injection pump spooge normal?
Postby Begle1 » Sun Apr 08, 2007 7:03 pm
So I took (from what I can tell virgin) pump apart yesterday.
That red spooge normal?
Postby Rebel Ram » Sun Apr 08, 2007 7:16 pm
That chamber should be dry if not at least clean. Perhaps the O-ring at the actuator pin is bad but thet still doesnt explain the red greasy content. Pull the pump top off and see whats in there.
"Big Ugly"-93 3/4 T extra cab 4X4 5 speed
"Big Hips"-92 1 Ton reg cab 4X2 Auto
"The ohwun"-2001 3/4 T quad cab 4X4 auto
Rebel Ram
Postby Begle1 » Sun Apr 08, 2007 9:55 pm
Well, that's not good then.
I had a bad O-ring on the main fuel screw... What's the "actuator pin"?
Postby 90firstgen » Mon Apr 09, 2007 12:03 am
Wow, that is not healthy!
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby JLeonard » Mon Apr 09, 2007 12:56 pm
I hate to say this but it looks like rust. Maybe some moisture got in there?
Does it wipe off easily?
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby Begle1 » Mon Apr 09, 2007 2:47 pm
It's not rust on the pump surfaces itself. It all came off, but it was stuck on their pretty good; kind of like hard water deposits on a faucet. Didn't score the metal.
Maybe I just caught it at the wrong time of the month?
Postby wannadiesel » Mon Apr 09, 2007 2:49 pm
The spooge is normal, I see that a lot. The liquid fuel is a bad sign. Time to pull the pump top and replace the seal around the pin.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Mon Apr 09, 2007 3:58 pm
wannadiesel wrote:The spooge is normal, I see that a lot. The liquid fuel is a bad sign. Time to pull the pump top and replace the seal around the pin.
What's the spooge from? Any idea?
Just because it's normal, does it make it acceptable? How long until it comes back?
I have a seal kit on the way; for all I know the seals could very well be original, and running with ULSD for the past few thousand miles (if you think that'd make a difference).
Is the fuel leak damaging anything?
Postby wannadiesel » Thu Apr 12, 2007 4:27 pm
The spooge appears to be broken-down grease, moisture, and rust.
It'll come back in a few years if you clean it all out.
The fuel leak isn't damaging anything. As long as it's not leaking enough to bother you, there's no reason you can't drive the truck.
Best dyno: 408/844
wannadiesel
diesel guru
