water pump
water pump
Postby oconnellrb » Sun Oct 04, 2009 8:58 am
I need to put a new water pump on my truck anything special i need to do?
1983 crew cab 89 motor 1st gen inter cooler hx35 518 auto shift kit and converter divorced 205 transfer case 93 core support.
oconnellrb
Postby Richie O » Sun Oct 04, 2009 1:15 pm
The hardest part is taking the belt off and on. If your truck has lost the belt routing diagram make your own before you pull the belt off.
Postby oconnellrb » Mon Oct 05, 2009 9:46 pm
Shounld a use any kind of rtv or silicone?
oconnellrb
Postby ahale2772 » Tue Oct 06, 2009 9:08 am
yes i alwasy put a thin coat around the gasket make sure both surfaces are clean dry and oil free
