99 24v p-7100???
99 24v p-7100???
Postby Mike6bt » Thu Oct 15, 2009 6:56 pm
i found a 99 24v for cheap in need of a new i/p and i was wonderin if anythin special was involved in p-pumping it any insite would be appriciated.
91 3/4
-straight pipe
-no i/c
-slightly massaged pump
Mike6bt
Postby dieselhotrodder » Thu Oct 15, 2009 6:58 pm
yea, you gotta change the entire front timing cover and gear. and then get all the proper conversion lines and linkage. BUT MAN IS IT WORTH IT!!!
dieselhotrodder
Postby Mike6bt » Thu Oct 15, 2009 7:00 pm
soo pretty well gotta get a donor truck then eh
91 3/4
-straight pipe
-no i/c
Mike6bt
Postby ahale2772 » Thu Oct 15, 2009 8:33 pm
and injector lines... but a p/p'ed 24 would be way cool
Postby Mr. Bob » Tue Oct 20, 2009 2:46 pm
2002 F350 with all the go fast mods 450 RWHP
1995 F350 CCLB 4X4 project CTD swap...
Mr. Bob
Postby ahale2772 » Wed Oct 21, 2009 7:36 am
im entertaining the idea of a ppump swap in my truck anyone know if the angle of the ppump injector lines is the same angle as the injectors on my non-icd head? i just had a ppump 12 valve from a bus fall on my lap im young and greedy for power... i have the whole motor available if anyone wants a short block/misc parts and or if anyone reallyyy wants the ppump conversion
Postby ford69557ci » Wed Oct 21, 2009 8:35 am
The ppump sticks use a different thread where the injector line goes on. The placement in the head is the same on all 12v motors just the spray pattern of the injector is different.
ford69557ci
Postby ahale2772 » Wed Oct 21, 2009 8:39 am
ok thanks a ppump would most likely run 7mm sticks right?
Postby ford69557ci » Wed Oct 21, 2009 10:45 am
yep they are 7mm
ford69557ci
Postby Mr. Bob » Wed Oct 21, 2009 11:02 am
To P pump a 1st gen engine dont you run the P pump injector bodies with the 1st gen nozzles to keep the correct spray pattern?
Mr. Bob
Postby ahale2772 » Wed Oct 21, 2009 11:43 am
Ford69557ci I have a complete 12v ppump motor do u think it would be easier to just do a motor swap than take my ve apart and put the ppump stuff on?
Postby rattlebox93 » Wed Oct 21, 2009 1:15 pm
you dont have to get a new timing cover just the new gears the p pump will bolt on where the vp did
rattlebox93
Postby Begle1 » Wed Oct 21, 2009 1:16 pm
ahale2772 wrote:Ford69557ci I have a complete 12v ppump motor do u think it would be easier to just do a motor swap than take my ve apart and put the ppump stuff on?
YEAH, not to mention that you would keep two running engines that way instead of one dismembered engine and one freankensteined engine. 8)
Postby ahale2772 » Wed Oct 21, 2009 1:22 pm
thats what im thinking....i want to keep the ve a mostly stock engine and try to gona try to keep the allison at545 behind the ppump motor those are UNBREAKABLE even iff i have to use a 55 gallon drum as a trans tunnel in the cab :) but that would mean a divorced transfercase and i dont want to get that deep so ill probably do a getrag when the time comes
Postby ford69557ci » Thu Oct 22, 2009 9:32 am
Whe I worked on buses we had a pile of burnt up at545 trans. They work fine until ya start puttin the power to them. I have done a few p pump conversions on a ve motor and I think it is easier to just do the whole engine swap.
ford69557ci
