my 5.9 shakes your teeth out
Postby dieselhotrodder » Sun Oct 18, 2009 6:53 am
i have a 92 w-250, this thing rattles your teeth out sitting in it idling. then its fine when your get the r's up... what the heck!?? anyone know.?? o have 2 other cummins and nothing like htis
Last edited by dieselhotrodder on Sun Oct 18, 2009 8:34 am, edited 1 time in total.
dieselhotrodder
Postby 2stroke » Sun Oct 18, 2009 6:56 am
i will bet that your idle is set too low. try turning it up, see what happens.
91 non I/C w-350 SRW
2stroke
Postby dieselhotrodder » Sun Oct 18, 2009 8:20 am
idles at 800-1000. it has a factory tach in it.. cant undersatand it
dieselhotrodder
Postby Begle1 » Sun Oct 18, 2009 8:37 am
Pump stock?
What RPM does it smooth out? Or does it only smooth out when there's a load on it?
Postby Richie O » Sun Oct 18, 2009 8:38 am
At 800 it should be smooth as glass. I had one truck that was real low and it would turn the screws out of the trim at a stoplight. :D
Postby dieselhotrodder » Sun Oct 18, 2009 10:11 am
ya, rpms seem stock.. this truck is 1 owner never touched. even the original paperwork is in the glove box. i jsut checked the idle. it idles at 700-750 almost 800. if you bump the gass it smoothes out.. odd. my other trucks idle lower.
dieselhotrodder
Postby Begle1 » Sun Oct 18, 2009 3:23 pm
Hmm...
The timing may be advanced due to low pop pressures? Take the injectors out and have them clean/ pop tested/ reshimmed?
Usually an injection pump or injector problem that results in a rough idle will cause an RPM drop; fixing the problem will give some RPM back.
How much RPM do you have to give it before it smooths out?
How fresh is your fuel?
Postby cummins king » Mon Oct 19, 2009 8:01 pm
Bad/ dirty Injectors, or lack of fuel because of lift pump or filter.
93 4X4 auto
cummins king
Postby cougar » Sat Oct 24, 2009 9:05 am
My 91 started doing that after I replaced the transmission mounts. At idle it rains screws in the cab.
01 2500 "the work truck".
cougar
Postby oilcan64 » Fri Nov 06, 2009 7:43 pm
mine almost does the same, it shakes some horrible when i shut it off
motor mounts?
1992 - w250 - 5 speed - LE - Reg. cab - 8' bed - minor pump tweaks - srw - ic
KDP & Killer Bolts killed
Saving for body work!
oilcan64
Postby cougar » Sat Nov 07, 2009 9:20 am
My 91 also has and always did have a good shake on shut down. My 92 has a good belt squawk on shut down.
cougar
