off highway diesel
off highway diesel
Postby redwood logger » Wed Oct 28, 2009 3:11 pm
What are the pros and cons of running off highway diesel in a cummins. Will it eliminate the need for addatives?
redwood logger
Postby Richie O » Wed Oct 28, 2009 3:20 pm
Con's. The tax man will take you to jail. :roll: All of our fuel here is ultra low sulfur including heating oil. We used to be able to get the GOOD stuff for off road equipment and heating oil. They actually made it against the law for boats to run the ole good stuff. As far as I know the only difference is the color.
Postby dieseljack » Wed Oct 28, 2009 4:31 pm
My family has been in the oil biz for nearly 50 years only thing is the dye and awhole lot cheaper
1991 w250 rebuilt auto 170xxx Straight 4" turbo back dennyt stage2 fuel pin pump turned up 1/4 from bad new era 370s
dieseljack
Postby gear jammer 91" » Wed Oct 28, 2009 6:14 pm
The only way you'll get caught is if you tell people, or you get your tank dipped. I've been driving commercial trucks for six years and only had my tank dipped once, and it was by someone from the IRS if I remember right. In a pickup I've never been checked. Too bad the off road stuff isn't the old high sulfur fuel.
01 LB7
gear jammer 91"
Postby Richie O » Wed Oct 28, 2009 6:20 pm
Standard practice here in Maine for the Commercial truck police to stick the tank. A guy in town got busted for it and he had to pay a few thousand to get his truck released. They then went to his yard and tested the rest of his trucks. It cost him more. :D They even sucked a gasser truck once while the driver laughed at them. The cop says " Hey, thats gas not diesel ". He said " Last I knew a gas engine ran on gas ". :D
Postby Farmboy » Thu Oct 29, 2009 5:49 am
There are some guys around here that run it in there trucks. I don't don't think I would take that risk. I can't afford the $$$$$$$$ fine. :shock: although it would be nice to avoid the tax man! Maybe I'll start running veggie oil :D
Farmboy
Postby MMeier » Mon Nov 02, 2009 10:27 pm
Farmboy wrote:There are some guys around here that run it in there trucks. I don't don't think I would take that risk. I can't afford the $$$$$$$$ fine. :shock: although it would be nice to avoid the tax man! Maybe I'll start running veggie oil :D
same thing will occur if they find it... unless you paid road use taxes on what you use .
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby FLCMP » Thu Nov 19, 2009 10:59 pm
I ran the offroad diesel in a 92 for two weeks and the only difference i noticed was that it smoked alot more than the ultra low sulfur diesel at the pump
FLCMP
Postby KTA » Fri Nov 20, 2009 8:11 am
There is no diffrence here besides the dye in on and off road fuel. Personaly I like the ULSD as I gained about 1mpg consistently when they switched. Sulfur is abrasive and damaging to fuel systems anyway. It used to be the process required to remove it was what took the lubricity out. As long as the fuel is good quality ULSD is better for your fuel system and engine than High sulfur fuel. The DOT checks truck tanks around here all the time even in parking lots like walmart. They have found it to be a good way to raise the funding they need to keep their jobs as the tax incomes have decreased from the slowing economy. Personaly I don't think the $10,000 donation can ever be made up in the 20cent a gallon diffrence.
Postby BobS » Fri Nov 20, 2009 9:10 am
Price differences vary state to state dependent upon how greedy your state is. PA is very greedy. The difference in price is generally in the 50 - 60 cent range here. This has been quite consistent during our governor's two terms.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby Richie O » Fri Nov 20, 2009 9:56 am
Its over 50 cents a gallon tax here in Maine. We are a small company and our fuel bill is several thousand a year. We might be able to save a few thousand a year if we did not pay road tax. Getting caught once would cost more then the savings of 2 or 3 years. Not really worth it. We have 2 bulk tanks. 1 for off road and 1 for on road. Just put over a hundred gallons in one truck today. :roll: When fuel was sky high we could burn close to a hundred gallons per day ( on a long day ) and with 2 trucks hauling the bill would be over a grand. :evil:
Postby doublel89 » Sun Nov 22, 2009 8:28 am
Works out slick for me, I have a 2nd tank under the rear of my bed, the opening is hidden behind LR wheelwell. I fill my stock tank with clear diesel and rarely use it and run off my 2nd tank filled with the red go go juice. Dbout I'd ever get my tanks dipped in a pickup, if I was goin to I guess I'd have to play really stupid then.
91 3/4 Ton 4x4, 5.9 Cummins,DDP Fuel Pin I usually leave it out though, DDP 40 Horse Sticks, HX35W And 2nd Gen Intercooler, Single 5'' Trunout, NV5600 Swap, Dually Conversion, 3.08 Rear Gears, Soon A Custom Hauler Bed
doublel89
Postby oldestof11 » Sun Nov 22, 2009 11:39 am
doublel89 wrote:Works out slick for me, I have a 2nd tank under the rear of my bed, the opening is hidden behind LR wheelwell. I fill my stock tank with clear diesel and rarely use it and run off my 2nd tank filled with the red go go juice. Dbout I'd ever get my tanks dipped in a pickup, if I was goin to I guess I'd have to play really stupid then. :scratch:
No offense but its people like you that make the rest of us pay. Not only that but since you posted on a public place, all they have to do is type diesel forum in the google bar and find this place, subpoena to get a IP address and get your info. Or they get rid of the off highway advantage and make everyone pay taxes which then require the companies to make everything more expensive for the rest of us.
Same thing with people and illegal aliens on welfare....
Off the soap box.
Postby RumbleFish » Sun Nov 22, 2009 12:19 pm
omg, puckett is that you???
Postby Ace » Sun Nov 22, 2009 1:12 pm
It's hard for me to imagine how anyone could get better mileage with ULSD since the process of removing the sulphur also leaves around a 1% less energy dense fuel with lower aromatic content. It also reduced lubricity to the point where they had to come up with a new lubricity standard (ASTM D975), which basically amounts to the suppliers blending their own lube adds at low level terminal locations.
ULSD is just another angle on the government's overall stupid energy strategy, right along with ethanol, wind, yad, yada. Of course all great ideas that didn't get thought all the way through before billions were spent and the damage done. Damage to injector pumps and injectors in our case.
Y'all go ahead and trust Shell, XOM, BP etc. to make sure they add plenty of Powerservice to your fuel before they top off the tanker truck on the way to your location now! :P
Ace
