oil pressure
oil pressure
Postby dieselhotrodder » Wed Nov 11, 2009 5:19 pm
my 90 non ic has some wierd oil pressure things goin on. its like some times when you fire it up its in the middle of the gauge. then others its on the last white bar towards the low side.. i was wondering if you guys could show me yours and maybe some thoughts on the matter.
dieselhotrodder
Postby mprmn08 » Wed Nov 11, 2009 5:49 pm
common with the factory oil pressure sensor. hook up a mechanical gauge and it shouldnt do it then unless something is wrong.
mprmn08
Postby darestie » Thu Nov 12, 2009 1:13 pm
Also your oil pressure will be higher in a cold engine, it drops as the engine warms up.
1993 D250, 5speed. starwheel turned, ASA Intake, M&H M3 fuel pin
darestie
