Another injector question
Postby 92 D/UNIT » Mon Nov 16, 2009 6:58 pm
was wondering if someone could identify this Bosch inj #? Also will a 2nd gen injectors work in a I/C 1st gen if you have the pop pressure set to 1st gen specs?
here is the part # KDAL 59P 7 / 0430132006
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby ford69557ci » Mon Nov 16, 2009 8:43 pm
the second gen sticks will not work. The p pump second gen injector bodies use a different threat where the injector lines go on. Your can put the scond gen tips on 7mm 1st gen bodies and have the pops reset.
ford69557ci
Postby PToombs » Tue Nov 17, 2009 6:35 pm
Even then the spray pattern is different. It may smoke more and not burn as good as the same size aftermarket with the correct angle.
