Thermostat housing - is this what I want?
Postby Farmboy » Thu Nov 19, 2009 5:21 pm
Like the title says... is this what I want to convert my truck to intercooled front clip.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33603
Farmboy
Postby SNOOT » Thu Nov 19, 2009 7:43 pm
nope.. thats a 2nd gen..
1993 W350
SNOOT
Postby Raymo » Thu Nov 19, 2009 8:39 pm
I'm running the same second gen housing on my 89 engine with that hose plugged off using a normal pipe plug. I used the second gen thermostat too, but I dont know if that makes any difference. Works just fine for me.
'94 Chevy 3500-HD cab and chassis- IC Cummins, Getrag, NP205. 60 front, 80 rear- 4.10's.
Raymo
Postby Farmboy » Fri Nov 20, 2009 5:21 am
I am aware that it is a 2nd gen t-stat housing. From all of my research I am told it will work I just need to have all of it. I was more or less asking if it was all there. I don't know what it is supposed to look like. I know the 24 valve motors have a seperate water neck but this looks to be all one piece. Again I think this IS what I want, just verifying.
Farmboy
Postby Raymo » Fri Nov 20, 2009 9:16 am
All I see missing is a thermostat and the rubber that holds it in. Looks exactly like mine, which is all one piece so all you need is a hose. I looked at my intercooled 93 this morning and its that thermostat housing without the small hose provision.
Raymo
Postby SNOOT » Fri Nov 20, 2009 9:26 am
Listen if you want one like the one on ebay I will ship it to you for FREE!!! Good luck making it fit correct..
You may get it to work with the correct lifting plate bracket from a 2nd gen but no go with the 1st gen bracket...
Its a clearance issue the rubber gasket will not sqwash causing the thermostat to be loose and leak water. I tried both rubber gaskets 1st gen and 2nd gen. The tolerance on the lifting plate I think is different causing the problem.
1993 W350
SNOOT
Postby Farmboy » Fri Nov 20, 2009 10:40 am
I already placed a bid on the one on ebay... it was a small bid so if I get out bid I will take you up on that, Snoot. I should be able to come up with the right spacing even if I have to custom machine a new plate. That should be no problem with all the steel we have laying around the farm. I will keep in touch.
P.S. I wasn't trying to cop an additude with you. If you thought I was I appologize for that. :D
Farmboy
Postby bgilbert » Fri Nov 20, 2009 4:14 pm
The 2nd gen 12 valve t-stat housing requires the use of 2 different square cut o-rings or gaskets, not the single donut gasket used with the 1st gen t-stat housing. Keep in mind the t-stats are different themselves in size. You can't use one or with the other. 1st gen housing, 1st gen t-stat. 2nd gen housing, 2nd gen t-stat. BTDT. 90 engine, 94-98 t-stat and housing. Snoot I'd be happy to take that off your hands :lol: . I'm actually gonna need another one for my twin truck. It's getting a face lift in the near future ;) .
Bill Gilbert
bgilbert
Postby SNOOT » Fri Nov 20, 2009 6:48 pm
bgilbert wrote: I'm actually gonna need another one for my twin truck. It's getting a face lift in the near future ;) .
Its yours if farmboy gets his. In the end I just wanted the air bleeder. I drilled and tapped my 1st gen one and put the fitting in the head. Done deal.
1993 W350
SNOOT
Postby Farmboy » Tue Nov 24, 2009 5:45 am
Snoot, you can go ahead and send that to Bill I got mine.
Farmboy
