cooling system
cooling system
Postby jwatso8 » Fri Nov 27, 2009 2:06 am
my question is does anyone know what the stock coolant fan pulls as far as CFM's. i was wanting to replace mine with an electric fan but dont know the CFM's. truck is just a play toy, just dont want it to get to hot. also what is the thermostat set at, so i can get the right thermostat/relay kit. thanks
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby chico_mustangs » Fri Nov 27, 2009 11:33 pm
I am wondering the same thing...
chico_mustangs
Postby jwatso8 » Fri Dec 04, 2009 12:41 am
hey guys, i was thanking of going with summitracing.com high performance fan. part # SUM- 320718 aluminum 6 blade fan. said its 18" moves 2100cfm at 14.2 amps. i was thanking that would be ok becuase its only a play toy and its priced right for me at $94.95 what do you guys thank or should i go with dual fans? thanks.
jwatso8
