Need thoughts on Pacrake E Brake
Postby Bschwarzli » Mon Nov 30, 2009 3:53 pm
So I am in the process of replacing my cracked downpipe and while doing it, I thought it might be a ood idea to do an ebrake install now that I am a 5 speed! :D
Have been looking at two options but need advice:
Option 1 - PacBrake Inline PRXB with Stans Headers 4" turbo back system. The downside is the only spot to mount the brake that I could see would be right behind the transfer case pipe.
Option 2 - Go with the regular PacBrake 14000 ebrake, and it bolts to the turbo, and use a Pacbake downpipe designed to work with the e brake. The downside, I would have to figgure out a pipe to go around the t case.
So this is where I sit!
I am very open to thoughts and opinions!
What should I do?
Robert
1993 W350 Dually Crew Cab - 1997 12V, NV5600, NP205, Dana 60 F, Dana 80 R, Gear Vendors, PDR Twins, 4 link rear, so mostly stock really :)
1990 W250, NV5600, 3.07s, Gear Vendors, Super HX40, kinda stock :D
Bschwarzli
Postby ahale2772 » Mon Nov 30, 2009 4:55 pm
hood stack after the brake :)
Postby RumbleFish » Mon Nov 30, 2009 5:15 pm
i dont think it works like that....
just make sure you get a brake. it is WELL worth it imo. as soon as i can come up with a dp, im putting mine on.
Re: Need thoughts on Pacrake E Brake
Postby Bschwarzli » Mon Mar 29, 2010 4:14 pm
I did install a 4" inline pacbrake PRXB welded into a Stans Header 4" downpipe....
Just giveing an update. It CAN be done! :mrgreen:
Bschwarzli
Postby RumbleFish » Mon Mar 29, 2010 5:51 pm
and how do you like it?
and where is the update on your crew???? we want pics!!!
Postby Bschwarzli » Tue Mar 30, 2010 5:40 am
Crew is to be picked up this week from the second round at paint. The first was faulty primer so there was issues. Not much pics or anything as it has been there since October. :cry:
As for the 4" and prxb, yeah. I LOVE it! SOOOO glad I went with the stronger brake. SOOO worth the effort. Sound got much deeper too! :D
Bschwarzli
