hello
hello
Postby Power Ram Man » Tue Apr 24, 2007 5:40 pm
hello im power ram man from the cummins forum tomtom told me to join its pretty cool now for the question why will my truck not power brake its an auto 3:54 gears posi rear and front pumps been turned smoke screw 2 notches straight piped and a BHAF i cheaked to make sure the cable was opening up all the way and it is so i dont know what else it could be i guess its just a slow truck that wont pass a 4 cilinder for some reason i cheaked for leakes im lost :?:
92 3/4 Cummins with coverted getrag 5 speed, 4x4 PODS,3200 Gov spring,16cm housing, 4inch exhuast homemade downpipe, water meth,hx35 turbo,5 inch stainless intake with AFE filter, fuel turned up, timing bumped boost,pyro guages, Denny T fuel pin,coolertubz,piston lift pump
Power Ram Man
Postby KTA » Tue Apr 24, 2007 7:35 pm
Put a 12cm exhaust housing on it. It will power brake then. 8)
Postby CAJUN 93 » Wed Apr 25, 2007 6:07 am
my wifes stock truck won't spin the tires on a wet road (no kidding). alot has to do with the stock torque convertor. they are junk. my truck with the std trans can be kinda scary to drive in the rain :o . however, i don't do burnouts with it very often as the stock clutch doesn't enjoy them :lol:
CAJUN 93
Postby Greenleaf » Wed Apr 25, 2007 9:08 am
To perform a burnout with the OEM equipped 21cm housing (turbine) requires slight modifications. :wink:
I blew the tread off of one during a "demo" which took off the trim molding and folded the fender up and under the bed. Two of the bed cross members are smashed nearly flat. Paint damage etc.etc.
The 21 will generally prevent this. If I ran a 12, things could really get ugly. :evil:
BTW, when you type, please use punctuation. With out it, your question becomes difficult to read.
Greenleaf
tech specialist/mod
