Bellhousing adapter
Bellhousing adapter
Postby DDT » Wed Dec 16, 2009 6:06 pm
I have obtained a 47rh transmission and need the adapter from the same donor....95 2500.. I have been unable to get the torque converter off because the engine was given the cash for clunkers lockdown treatment and I can't turn it to access the converter bolts. Somebody stop me before I light the torch!
9 3 W350 Club Cab,DRW, K&N filter, pump adjusted, 366 spring, 16cm GDS 60cm, 4 in exhaust, Diprocal boost/EGT, PODs on the way out
DDT
Postby PToombs » Wed Dec 16, 2009 6:16 pm
Is the engine out? If so, pull the pan and loosen the bearing caps, should turn then. If not, torch time! 8)
Or, just order a good converter, and turn in your old one in the truck as a core.
FYI, lockup converters are usually about $1200. :cry:
