Are Lucas fuel pump any good? I'd assume they'd be better than Airtex, but maybe not as good as Carter? I found a piston lift pump for a 4BT, Lucas p/n HFP702, and was wondering if it'd work for a piston lift pump upgrade for my 93 W250. I know the 1stGen piston pump is originally from a 4B application with a P-pump, but that's about all I know.
Thanks guys,
Dan
