rpm wobble?
rpm wobble?
Postby ahale2772 » Wed Dec 23, 2009 8:07 am
i was cruisin around yesterday and took my truck out on the highway seems like anywhere over 2 grand there is a constant vibration that comes in goes at a constant interval, it also happens when i just rev the engine at a stop , one second on one second off, i dont really know what a cummins has for a harmonic dampener of if they ever have any common problems with vibrations, anyhelp? thanks
Postby KTA » Wed Dec 23, 2009 8:48 am
They have a rubber ring mounted dampner. I have seen them deteriorate and that could be your problem. You can take a look and see if there is anything obvious. If there isn't put a white paint mark on the 2 halves and run it for awhile. If the marks don't line up anymore the dampner is junk.
Postby ahale2772 » Wed Dec 23, 2009 1:42 pm
ok thanks ill look into it anyone make a hi-po replacemt one like a fluid dampner?
Postby KTA » Wed Dec 23, 2009 2:42 pm
Postby skilletky » Fri Dec 25, 2009 6:45 pm
do ya gotta modify anything for it to work? i am having the same problem with my truck.
skilletky
