Crap.....12deg + my setup + 15k trailer = lotsa welding
Postby eyoung429 » Sat Dec 26, 2009 8:17 am
Let the rig warm up and went out to load up a buddy's truck. Didn't leave mine running while we winched his rig up (blew the driveshaft) thought that it would still be warm 35min later.
Started up a 20deg incline and all the sudden had a lurch and sounded like my engine was going to come through the cab.
Pulled over and found my exhaust manifold in 3 pieces!!!!!
AAARRRGGGHH!!
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby KTA » Sat Dec 26, 2009 9:50 am
That is unusual. Might want to check if you have some broke mtor mounts. I have seen those fail and let the engine move enough to crash the exhaust into stuff. It could probably even put enough weight on it to break the manifold. I wouldn't think it would break just from the cold unless it was ahuge temperature swing like start it up cold and tromp on it pulling a load.
Postby eyoung429 » Sat Dec 26, 2009 10:24 am
Yep....ripped the driverside mount.. Can see where my dp hit the firewall...
luckily I have a new set of mounts...bad news is now I have to splurge for the ATS......
eyoung429
Postby dpuckett » Sat Dec 26, 2009 10:47 am
I bet that will break your heart, lol.
Postby eyoung429 » Sat Dec 26, 2009 10:51 am
yep....at least I have a very good excuse for the wife....pulling the remaining parts and laying them out.
eyoung429
Postby MMeier » Sat Dec 26, 2009 10:03 pm
Anyone recall a set of polyurethane mounts that is (were) available for our beasts ?
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby GLHS » Tue Dec 29, 2009 10:52 pm
Poly mounts for the engine; www.autoworldmt.com
Poly mounts for the transfer case; www.polybushings.com
The ATS is a nice manifold.
GLHS
