full power screw
full power screw
Postby Power Ram Man » Mon Apr 30, 2007 6:04 pm
how much power would i see if i turned the full power screw at the back of the pump? maybe one to two screws
92 3/4 Cummins with coverted getrag 5 speed, 4x4 PODS,3200 Gov spring,16cm housing, 4inch exhuast homemade downpipe, water meth,hx35 turbo,5 inch stainless intake with AFE filter, fuel turned up, timing bumped boost,pyro guages, Denny T fuel pin,coolertubz,piston lift pump
Power Ram Man
Postby Underpsi » Mon Apr 30, 2007 7:10 pm
it really is different with every pump but with two turns you will most likely feel a difference. Just try it and if you don't like it then make sure you remember how many turns so you can turn it back. Although you probably won't want to
1989 D250 5spd w/SB3250DD, .020 over head gasket, O-rings, Extensive port/polish, ARP head studs, 62/71/14, 6x.018 sticks. First Dyno stock turbo and pods: 343/879
2nd with 62 & big sticks: 393/813
Underpsi
Postby CAJUN 93 » Tue May 01, 2007 6:01 am
some pumps it will make very little difference, others will try to runaway. just be prepared with a board to shut it down, just in case. 2 turns on mine made for a completly different truck.
daryl
CAJUN 93
Postby Power Ram Man » Tue May 01, 2007 6:00 pm
Carolina Cummins lives right close to me i think im going to let him do it, he said you would feel the difference, but not as much because it has an intercooler
Power Ram Man
Postby 89dieselkong » Wed May 02, 2007 3:54 pm
On mine I only got 3 turns on it (with the collar off) before runaway. It is a whole other truck though :shock:
1989 W250 LE Power Ram, 5-speed, Old Smokey Mount w/K&N Filter, 4" exhaust, Isspro pyro/boost, Stage IV/12cm W/G, 3200 spring. BD fuel pin, star wheel 1/4 turn, full power screw maxed, Skyjacker 2.5/2.0 lift, BFG A/T 285/75R16...
89dieselkong
Postby oldestof11 » Wed May 02, 2007 3:55 pm
Mine only went in about 2 turns then I couldn't turn it no more. Does it get hard the more it goes in??
Postby TWorline » Wed May 02, 2007 5:19 pm
oldestof11 wrote:Mine only went in about 2 turns then I couldn't turn it no more. Does it get hard the more it goes in??
When it gets to where there is a lot of resistance that is the end of your adjustment. Some guys have taken it out and welded more on the end then milled it down for further adjustment.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby Begle1 » Wed May 02, 2007 5:20 pm
So what is the maximum number of turns people get? 6?
Postby seeker1056 » Thu May 03, 2007 4:44 am
hmm, not sure how many turns.
When i removed my power screw there were about three threads a smooth shaft and then a hex portion of the screw showing past the weldedd collar, and all of the pix I have ever seen of a stock screw/collar show just the hex end of the screw, not the shaft and threads.
I wanna say I had about 8-9 turns, and have yet to get to runaway.
Fact is I ran out of low idle adjustment first, tryin to turnin the idle down.
Currently I am sittin at 758 hot idle
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby oldestof11 » Thu May 03, 2007 4:37 pm
Shouldn't I get more turns tho?? And how will welding and grinding help? I am trying to learn here as one of these days, I want to mod these (swap parts). I guess I really want to know how it works and improve on it.
Postby PToombs » Fri May 04, 2007 2:11 pm
When you weld the end, you are making it longer, thus it pushes farther. It would be like having more threads.
There is a shoulder on the screw, this bottoms in the hole. The first part of the hole isn't threaded, this is where the shoulder (holds the o-ring seal) rides.
Postby oldestof11 » Fri May 04, 2007 5:28 pm
AHHHHH!!! *And the light bulb goes off* :P Thanks!
pump difference
Postby charger 69 » Fri May 04, 2007 8:24 pm
As you said it must be different between pumps,I turned mine 3.5 turns and no sign of it wanting to run away.
92 White D350 132K,mi. fuel screw in 3,5 turns automatic with a Hughes converter and 26K add on cooler.Aluminum wheels,second fuel tank,gooseneck hitch,air bags tach.and gages,
charger 69
Postby 90firstgen » Sat May 05, 2007 2:09 am
We had an unofficial poll on DTR awhile back and it seems that the non-i/c pumps tend to run away more than the intercooled ones. Not sure why...
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby CAJUN 93 » Sat May 05, 2007 6:37 am
just another reason you "intercooler challenged' guys have it soooo tough :lol: . makes up for ya'll have real injectors in it from the factory.
daryl
CAJUN 93
