shut off solenoid
shut off solenoid
Postby jwatso8 » Wed Dec 30, 2009 3:00 pm
is there a delete kit to remove the stock fuel shut down solenoid. i was just wanting to use the manual cut off with a cable. thanks
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby AHineman » Wed Dec 30, 2009 4:24 pm
I would just take the plunger and spring out of the solenoid and put it back in. 8)
Postby dodgetkboy78 » Wed Dec 30, 2009 6:38 pm
Mine did that all by itself.........
:oops: :oops: :oops: :oops: :oops:
Wonder where the junk from it went?
:mad: :mad: :mad: :mad: :mad:
dodgetkboy78
Postby Jfriedlin » Wed Dec 30, 2009 8:42 pm
I took my plunger and spring out cuz my solenoid went bad and truck no run no mo. Now its leaking out of the top cuz there is nothing holding the fuel back so I ordered a new one
Jfriedlin
Postby BC847 » Thu Dec 31, 2009 7:17 am
If you're gonna gut the fuel solenoid, be sure NOT to connect power to it. Without the plunger, the coil can overheat and possibly short out and/or leak. ;)
Postby Ace » Thu Dec 31, 2009 2:17 pm
I tapped mine for a half inch pipe plug after it started leaking past the plastic body:
http://stuff.is-a-geek.net/PhotoAlbum/1 ... TD_172.jpg
Ace
Postby Jfriedlin » Thu Dec 31, 2009 2:25 pm
I just got my new shutoff solenoid in the mail and installed it. I figured I'd get yuou guys opinions on this, when I started the truck up it would not stay running withou a lil throttle, like the idle was too low. So I adjusted the idle and all is well, but just as I figured, Im now lacking some power, about 6-8 lbs of boost less than before. Any ideas or opinions are welcome. Thanks
Jfriedlin
Postby dodgetkboy78 » Fri Jan 01, 2010 1:56 am
Air?
dodgetkboy78
Postby Jfriedlin » Fri Jan 01, 2010 3:17 pm
I dont think so. It acts like the index on the trottle shaft moved. It runs good and smooth, no smoke at all, not even black anymore. Like I said, it seems like the index on the throttle shaft is off but it was untouched
Jfriedlin
Postby Jfriedlin » Fri Jan 01, 2010 3:51 pm
I havent compared them, but if the plunger on the new solenoid was a lil longer than the old one could it possibly cause this type of problem?
Jfriedlin
Postby RSWORDS » Fri Jan 01, 2010 6:22 pm
Could... Since the stock plunger was still OK and it was just the electrical part that burned up can you swap plungers?
RSWORDS
