weird issue when idleing the engine up when cold?
Postby rattlebox93 » Sun Jan 03, 2010 8:48 am
i have a 92 250 stick pod's pump maxed out 3200 spring no afc intake exhaust and when its really cold out the truck will start fine idle fine but when you slowly start to rev it up it gets to about 700rpm and then falls off to about 400-500 rpm and idles really badly and when you keep reving it up past that fall off point then it will pick back up and run good after about 1000rpm but only until the engine warms up then the issue goes away....anyone seen anthing like that? any ideas? it did it with my stock injectors so i dont believe it is the injectors thanks
rattlebox93
Postby dodgetkboy78 » Mon Jan 04, 2010 12:37 pm
Sounds like a filter or lift pump.
dodgetkboy78
Postby burnt_servo » Mon Jan 04, 2010 6:18 pm
if you put the afc back in i'll bet the problem goes away .
my gut feeling is your dumping way too much fuel in without the afc removed and your putting " the fire out " so to speak , when the engine is cold .
slightly advancing the timing may help some what too .
'93 w250 .... stock ...
burnt_servo
Postby dodgetkboy78 » Mon Jan 04, 2010 10:59 pm
Wouldn't dumping more fuel cause it to rev up? :?
dodgetkboy78
Postby burnt_servo » Mon Jan 04, 2010 11:56 pm
dodgetkboy78 wrote:Wouldn't dumping more fuel cause it to rev up? :?
if the engine was hot , yes ......
cold engine , lots of fuel can equal what rattlebox is talking about .
think of it in these terms , take a very small fire ( less than 6 inches around ) at -30c , drop a 5 gallon pail of diesel that is also at -30 on the fire .
the fire goes out ......
do the same thing at +30c and you could have a huge fire ball .
burnt_servo
Postby ironeagle59 » Fri Jan 15, 2010 5:43 pm
I have intake exhaust and no AFC 3000 gov spring and bosch 190s on my truck and even when it was 8 degrees f it would rev up even when cold. Mine is advanced 14 degrees though so maybe that would help
ironeagle59
