Need Cummins Part Number for the turbo to downpipe clamp
Postby Bschwarzli » Mon Jan 11, 2010 11:10 am
Looking for the Cummins down pipe to turbo band clamp part number for the 1990. I seem to be leaking there now that I have the new exhaust in and I am going to assume the clamp is toast after 20 years! ;)
Found the Mopar PN of 4428550 but they want like $55 for it! Yikes!
IS there a Cummins PN for the same part?
Thanks!
If it helps, Motor Serial - 44411716
Robert
1993 W350 Dually Crew Cab - 1997 12V, NV5600, NP205, Dana 60 F, Dana 80 R, Gear Vendors, PDR Twins, 4 link rear, so mostly stock really :)
1990 W250, NV5600, 3.07s, Gear Vendors, Super HX40, kinda stock :D
Bschwarzli
Postby Mark Nixon » Mon Jan 11, 2010 1:22 pm
Better look at your pipe very closely, it's possible the ridge that the clamp compresses has a crack in it somewhere.
Postby PRINCETON_JAKE » Mon Jan 11, 2010 4:06 pm
I have seen the down pipes crack before, usually from a bad or missing hanger. I havent seen a clamp leak though.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Postby Bschwarzli » Mon Jan 11, 2010 4:06 pm
Mark,
All is OK. Brand new Stans Headers downpipe and it looked good. My issue was I reused the clamp and I am gathering that is a no no.
Robert
Bschwarzli
Postby Mark Nixon » Mon Jan 11, 2010 6:05 pm
Then many of us need our hands slapped, because it's done all the time. :lol:
I usually just carefully close up the 'v' area of the clamp with a pair of wide jaw visegrips, or a smooth jaw vise will work.
Don't go hog wild on how FAR you close up the gap, just do it uniformly and it works fine.
