60# valve spings??
60# valve spings??
Postby Kinship » Mon May 07, 2007 3:53 pm
This is my first post here. I have 93 D350 ,NV4500HD conversion,south west clutch,gear vendor,stans 4" ,16cm EX houseing .
I just added a US gear exhaust brake and want to put 60# exhaust valve springs in. can I do this with out haveing the head removed ?
Kinship
smoke screw?
Postby wannadiesel » Mon May 07, 2007 4:11 pm
Yes. You bring each cylinder to TDC and let the valve sit on the piston.
Best dyno: 408/844
wannadiesel
diesel guru
