stock91w350 wrote:i was driving today when my truck started bogging down bad and smoking wicked, then it kinda made some popping sounds, so i pulled over to look things over, only thing i could think of is that the air filter was to dirty so i took it off drove a few miles home and it seemed fine. the filter is a cone style hooked to a s shaped tube from the turbo over to the pass side fender, i put this filter on new in november and only have drove 1400 miles since. i do have a crack in my down pipe that lets some smoke out under the hood. how many miles should i b getting out of a air filter?
well i plowed with it all day and as the day went on i noticed it smokin more and more, then when i hit rt 1 it was smoken like hell and bogged down and popped alil. the filter did not seem wet but it was black as nite with soot caked onRichie O wrote:stock91w350 wrote:i was driving today when my truck started bogging down bad and smoking wicked, then it kinda made some popping sounds, so i pulled over to look things over, only thing i could think of is that the air filter was to dirty so i took it off drove a few miles home and it seemed fine. the filter is a cone style hooked to a s shaped tube from the turbo over to the pass side fender, i put this filter on new in november and only have drove 1400 miles since. i do have a crack in my down pipe that lets some smoke out under the hood. how many miles should i b getting out of a air filter?
Its snowing out, did you get clogged up with snow? was the filter wet?
PToombs wrote:Sounds like that was it!
Great, now there's a pair of Mainerds.
