stock91w350 wrote:my bad!, im a tard, found the real voltage reg, i was looking at some thing on my drivers side fender up towards the hinge. but the voltage reg looks new so im wondering if thats even my problem? even my radio started making weird noises the other nite while the lights were dimming down and then getting brite again
Philip wrote:Those things mounted on your wheel wells are the grid heater relays. If you had just started your truck when you noticed the lights going dim. That is a sign the gride heaters were cycling. Did the cycling stop after a couple of miles?
nope is does it alwaysPhilip wrote:Those things mounted on your wheel wells are the grid heater relays. If you had just started your truck when you noticed the lights going dim. That is a sign the gride heaters were cycling. Did the cycling stop after a couple of miles?
could be, its not under the drivers hinge its just past it toward the front of truck, a little metal box with a plug in going into the bottomAce wrote:I think he's talking about the vacuum sensor.
cool thanx, so sometimes u can get a bad volt. reg. rite out of the box? napa has a 15$ one and a 40$ one, i got the 40$ so lets see if it worksRichie O wrote:Philip wrote:Those things mounted on your wheel wells are the grid heater relays. If you had just started your truck when you noticed the lights going dim. That is a sign the gride heaters were cycling. Did the cycling stop after a couple of miles?
Last time I saw the truck it was doing the high low, bright dim dance all the time.
ok thank you, so the screw holding on is the ground?Ace wrote:Sometimes just a bad ground somewhere will cause that sysmptom, VR good or not. Make sure to clean up the spots where it bolt down and also run a ground from it direct to the exhaust manifold for best results.
