Oil leak
Oil leak
Postby Bad93Cummins » Thu Jan 21, 2010 6:45 pm
Where to find blown up view of cummins motor for a 93? Tring to find out whtat's on the behind the injection pump cause that's where my oil leak is coming from.
Thanks
Bad93Cummins
Postby PRINCETON_JAKE » Thu Jan 21, 2010 6:47 pm
my truck was leaking under the injection pump, because the nut was missing on the stud that woulds the pump on. :shock:
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Postby ahale2772 » Thu Jan 21, 2010 6:49 pm
there is a side cover running the length of the motor
Postby PRINCETON_JAKE » Thu Jan 21, 2010 6:55 pm
Yep, thats the lifter cover, they tend to leak. I recomend an aftermarket alluminum one, the stock ones are stamped steel. You have to pull out the injection pump and every thing else to put in a new gasket. :(
PRINCETON_JAKE
Postby Bad93Cummins » Fri Jan 22, 2010 5:00 am
Yea that's what me and my buddy was wandering/thought everthing had to come off, is that quite a pita?
Bad93Cummins
Postby PRINCETON_JAKE » Fri Jan 22, 2010 7:52 am
Bad93Cummins wrote:Yea that's what me and my buddy was wandering/thought everthing had to come off, is that quite a pita?
ITS NOT HARD JUST ALOT OF WORK.
PRINCETON_JAKE
Postby Bad93Cummins » Fri Jan 22, 2010 12:27 pm
That's good to know, looks hard.
Where can I get the upgraded peice?
Bad93Cummins
Postby dpuckett » Sat Jan 23, 2010 3:56 pm
I'd just get the gasket from cummins and replace it, and keep the original cover there. I mean, honestly, it lasted 15-20 years, the next one should last almost as long. Are you really going to have the truck in 15 years?
DP
Postby Bad93Cummins » Sat Jan 23, 2010 9:49 pm
id like to hope so. Yea I guess your right, just replace it with oem.
Bad93Cummins
Postby pulltilbroke » Sat Jan 23, 2010 11:59 pm
Have you checked all the side cover bolts, mine was leakin and I snugged em up and the leak almost went away
Postby Bad93Cummins » Sun Jan 24, 2010 5:56 am
No not yet. What gasket would that be called just incase i need a new one?
Bad93Cummins
Postby PToombs » Sun Jan 24, 2010 7:41 am
That's the tappet cover gasket.
Postby Bad93Cummins » Sun Jan 24, 2010 8:38 pm
Thanks!
Bad93Cummins
Postby Mark Nixon » Sun Jan 24, 2010 10:00 pm
PToombs wrote:That's the tappet cover gasket.
HMMMM!!! PRODUCTIVE!!!! :shock: :shock: :lol:
Postby PToombs » Mon Jan 25, 2010 6:48 pm
Yeah, I go thru spells. :oops:
